Avensis T2 D4d Timing Belt/water Pump Change
willied
hello
i have a toyota avensis t2 d4d year 2004 and it is due a timing belt change,my question is how hard is it to do this job and is it usual to change the water pump at the same time i have changed the timing belt in a carina petrol before without any problems and i was wondering were there any problems to be encountered on the d4d engine.
regards
willied.
hello
regards
willied.
Hi mate! click on or go to this link from a previous post and reply to your question. http://toyotaownersclub.com/forums/index.p...rt=#entry877412,
by the way you can always do a search in the top right hand box to look for previous topics an this may give you the answers quicker than waiting for a reply.
Best Regards Pete.
hello
regards
willied.
Best Regards Pete.
thanks pete for info i used that link
regards willied
To willied.
If your changing belt, make sure you change water pump as new belt can kill old water -pump bearings within a couple of weeks. I now no longer change belt on these engines unless owner agrees to change water pump as well. Its not hard to do , just a bit time consuming & make sure you use original parts.
Regards, Beagh.
