Vsc Off / Warning Engine Light /battery Remove Issues
kai3747
hi guys driving last night vsc warning light and engine warning light came on my dash (iq 1.0 2009) ,
as in the morning the same lights where on i remove the Battery for 30 minute as i read in a before post from this forum , and the problem solved .
After i took the car for a ride i noticed that the car was not working good ,it was working at about 300-500 rpm instead of 700-900, as it was working with 2 sparks .
Itook it to a friend of mine that has a car computer and he found that the problem was occured in the pedal of gas as when you take the Battery for a long period sometimes it needs the electronic of pedal to get in default .
I want to share this to all of you as maybe you have the same issue !!!!
Yes i have reported this before. Also the ECU latest map is lost so it takes a wile to rebuild it. Sometimes mine takes 2-3 miles to come good. Sometimes i have to dis the Battery a couple of times before all is good
David
