3sgte Engine?
lonepilgrim
Help me guys!!! Want some go from my show
Or please give me other options?
I have never done an engine swap in my life btw! So all help welcomed
I'd imagine the 3sgte into an E12 would be a mission what with the electrics. The easiest way would be a TS or CTS engine. Theres usually a tsport or 2 on eBay for parts.
yeah unless you make a custom loom and clock setup its a bit of a mare. fensport did theres and had to run 2 ECU,s . one for the engine and one for everything else.
getting the engine in and running wont be too hard just integrating it into the E12 ecu.
I looked into this when i had problems with my 2zz.
Same as above really. It's possible but will be very very difficult. i was quoted £5500 for a 3s-gte it to be fitted professionally and i had to supply the engine, that's more than the car is worth and i think it was quoted short and would have cost more than that.
I say the best swap would be a 2zz-ge, a supercharged one if you found one but i very much doubt it! For the time and money involved in a 3s-gte swap you would probably be better of building a 2zz-ge and running it with a garrett GT2871R. 400-500bhp to be had there i should think ;)
