Vsc / Trc Off Light
croni486
After driving 10-15 mile the VSC & TRC off light illuminate on my 1.8 VVTI Avensis. After stopping and switching off and on the light disappears again for approx. 10 -15 miles. I recently hit a big pot hole which damaged my wheel and tyre and looks like it has damaged something else.
I have put a code reader on the vehicle but has not brought any codes up yet. I need to have the tracking redone as the steering wheel is off centre. I've read that this may be the problem, although I would have thought the VSC system would have illuminated straight away.
Any ideas on what this could be. Could hitting the pothole have damaged the ABS sensor on the NSF wheel?
Sean
Sean
i have the same problem with my car, my code reader doesn't show up any codes either. from reading other threads the problem seams to be the abs sensor but will let you know when i get it checked out.
Checked the car out, and the ABS sensor was fine. After hitting the pothole the steering tracking was out so took it into ATS.
After doing the tracking and centralising the steering wheel the lights have not come back on. Thought it was going to be an expensive job, now i just need to sell the thing before something else goes wrong.
