Fog Lights
b1gpkr001
Hi all was thinking about removing the passenger side fog light and putting a air scoop in there for the air box to get some ram air effect.
The only thing I am worried about is will it effect the not only having one fog light and am I likely to be pulled over by the police?
might not pass mot's and may not be good when you resell!!! someone else might know more on here....
dont need front fogs for an mot just the o/s/r one. go for it i did it on my first zs :thumbsup: just watch out for deep puddles
When I resell will put it back to stock.
As for puddles I've got some bits from work that I recently removed from a aircraft it's a water catch tank/trap from a pressurization system and also have a magnetic by pass door to put in the ram air pipe so if the ram air pipe gets blocked then it will open and not starve the engine of air.
Want to try and keep it a closed loop ram air feed.
Going to remove my induction kit and put the standard air box back on and run the ram air pipe to it and fit a blitz panel filter.
Got to figure out how to fit it all in first!
Worth ago I think
