Show
Hello & Help With A Tsport Drivers Side Electric Window
#1
Posted 12 July 2012 - 09:46 AM
This is my first post on the site, my name is Paul and I am a massive Toyota \ Lexus Fan. I bought a 04 Pre face lift T Sport In March after owning a Starlet SR which I bought in 1999 and had for 6 years, a Corolla 2.0D4D for 5 years and an Auris SR180 for 11 months which I unfortunately had a lot of issues with so decided to go back to a Corolla petrol which I am really happy with.
The T Sport had one owner from new and had covered 58k when I bought it. So far I have had 5k of trouble free motoring and love getting it on lift and working my way through the box to keep it on that magical 6200 to 8200 rpm. Plus getting better MPG that the Auris used to.
I'm just trying to get the car as I would like it and one issue I have is the drivers window is starting to catch when it returns to the closed position and it is not always automatically shutting/opening when you pull the switch fully either way.
I cannot find any advice or other people with similar issues but three Corolla's I looked at when buying mine had the same issue so I think it might be a common problem.
Can anyone help?
Many Thanks
Paul
#2
Posted 12 July 2012 - 08:05 PM
Take the door panel off, and see if anything is catching or loose, as for a common problem . Not heard of it being one
Had mine over 3 years no prob's with windows
#3
Posted 13 July 2012 - 06:56 AM
As for the catching, can't help you there fella.
#4
Posted 13 July 2012 - 08:43 AM
I will try to reset the auto up down as you suggest and have a look to see if anything is causing the problem behind the door card.
I have seen a post about the regulators packing up which can cause a similar issue. I guess it's not common then I could always try a second hand regulator.
Cheers
Paul
#5
Posted 13 July 2012 - 03:48 PM
i've been a toyota tech for around 6 years and ive lost count of how many corollas ive had with this problem, even my own TSport did it.
#6
Posted 14 July 2012 - 08:52 AM
the catching noise will almost certainly be the regulator catching on the check strap, it normally will only do it when the door is closed, send the window up with the door open and it wont do it. What i normally do is remove the check strap and grind the corner off where it catches.
You star, thanks for the info. I will strip it out and sort it out.
Cheers
Paul
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
Latest Comments
More
