Auris 18 Inch Alloy
muffit23
Hi I have been looking into getting 18s on my auris. I've been told that they will fit but I'm not sure of the offset size? I was told if 17s offset would be 45, would that be the same for 18s... Any help would be appreciated
Hello Ross - welcome to Toyota Owners Club.
Topic moved to the Auris club.
You can generally vary by +-5 or so but if you reduce the inner clearance too much or push the wheel out too far, the tyre might rub or not fit at all.
You also need to inform your insurance company as otherwise your insurance will be invalid.
All depends how you want it to look. I've got 18x8 et38 front and 18x9 et35 rear and never had a problem with clearance. My car is also lowered 35mm front and 30mm rear. Tyre size is a crucial factor as im running 205/40/18 front and 225/40/18 Rear. Hope this helps
