Toyota D4D 2007 Verso 2.2 Heater Drivers Side Blows Cold Air
zdassu
Hi I was hoping some one could help me, my Toyota Corolla 2007 D4D 2.2 Heater takes a long time to get warm, once warmed up the drivers side still blows cold air while the passenger side blows warm air, does anyone know what the problem might be and is it an easy fix? your help in this matter will be much appreciated
Hiya,
I had a similar problem where my Verso took ages before the interior heating would blow warm. I had the thermostat changed which didn't help, but the mechanic found that the heater was partially blocked. He swapped over the inlet and outlet pipes and all started working after a little while. I'm not sure if this is an ideal solution as it really should be flushed through thoroughly, but it helped no end with my problem. Just be aware that the antifreeze is NOT cheap!
  • 4 weeks later...
