Replace Engine 2.2 D-4D Dcat
muurman
my head gasket is blown.
the car is from 2005 so an early one.
can i just swap the engine with an engine from 2009 of newer? This because with them the problems should be solved?
No an engine from a 2009 onwards will not be a straight swap, both the head and block are different between a t25 and t27 Avensis so you have to carry out extensive modifications to your Avensis to make the new engine fit
