Water In Drivers Foot Well In Yaris Verso
speed58
Hi just noticed this issue ...cant see where it is coming from ....any ideas had car for over a year and never had this issue before
Many thanks
Absent any other responses ... I don't know about Verso specifically, but the obvious places to check are the windscreen seal (usually buried behind dash trim) and ventilation ductwork (usually buried behind dash), particularly on some cars where blocked water drains can cause the rain to 'overflow' into the car.
Door seals and the membrane behind the door panel can also be problems. For the latter, remove the inside door trim panel and check that the (usually transparent) plastic film is properly sealed to the door metalwork, especially at the bottom.
