To electricians
ktsortanidis
Hallo to every one,
Concerning the new AYGO (mk2).
I'm trying to find a pin or a cable which carrys on an ''Engine running'' electrical signal in order to operate a relay.
Does anyone know where could it be located?
5 minutes ago, ktsortanidis said:
Hallo to every one,
You could use a 12v relay connected to the wiring for the power/cigarette lighter socket.
sure it is not activated turning the key switch?
I want it to be activated only with the engine on.
Ok, you could tap into the DRL power feed, as long as you are using a relay with low current draw.
They (DLR) are going off when we turn on the night lights (while the engine is running).
Good point :blush:
Do you mind me asking, what your objective is with the relay and engine running?
I want the head beam and fog lights go off  while we turning off the engine (only position lights stay on)
Making a second thought, there is no meaning of making this (engine running) because if I use the option you suggested (power/cigarette lighter socket)
the job will be done.
Meanning that when the key switch does to off position (engine stop) then the lights I want to control will be off.
