Fuel Cut Defender
jonnyb
Any advice on fitting a Fuel Cut Defender would be appreciated
I fitted it to the wires as advised in the instructions
1 wire went to the pink and blue +5V, fatter wire than the rest , closest towards the rear of the car
1 wire went to the TPS signal wire , on the connector block closest to the front of the car (4th pin in ) , a black connector block
1 wire went to the brown wire on the same connector block above (top right hand corner of the connector block)
Does this sound correct ????
Its now fitted and the fuel cut kicks in !!!
the instructions tell you to unplug the ECU fuse , wait 30 seconds and then turn the FCD down a little bit from max.
I'm in the process of doing this but want to make sure I've definately wired it in correctly
Thanks for any advice , PS what is the max boost I should run it at without engine engine mods in BAR ???
Jonathan
