Double Din Facia Adapter
dale69v
what kind are you after? wires or the face plate , double to single that hides the hole?
Basicly ive bought a kenwood double din unit and i need the plastic facia as the one i have is too small i would show you pics but i dont know how ?
the plastic clip that goes all around the din units edge you mean . how can the kenwood 1 be too small ??? mind boggles.
Is this for the MR2 in your details, or a yaris.
Can you explain exactly what you are after and what you have ..
have you gone from a double din to a single ?
right :)
You need to pop to Halfords and get one of their facia's .. not too expensive, and there is usually a few brackets as the cages are too small obviously ..
I know when you want to fit a single din h/u in a double din space the facia adapter needed is marked for the rav4 but does fit the yaris
So maybe try the one for the rav4 see if Halfords will let you try before you buy
Just an idea
still no joy mate???
ill have a look into it soon........
(as per phone call!)
the dash section that you use along with the Halfords rav4 bit is too small for a DD headunit
but im sure ive seen a yaris fitted with a DD stereo!
im thinking ive mainly seen it on LoVitz but that could take me a while to plough through and find!
Ah right, that's a bit **** from Mr T, Im sure I had a dbl-din cage around somewhere..(?) have a look tonight. He/you dont want to go cutting the plastic fascia, it's soo soft, very hard to make a decent job. U'll end up getting the filler out...
Good luck tho. :thumbsup:
