Hks Turbo Timer
jonnyb
I just bought a turbo timer and a wiring loom for my ST185 , I've stripped steering column ready to fit
In the instructions it says to wire into ign2 ??
I can see a similiar connector at the bottom right hand corner underneath the steering wheel. Is this the right place to connect to and then just simply earth it ?
Any advice would be appreciated
Jonathan
is yours JDM or UK spec? is the wiring loom JDM or UK spec, what year is your car, which year is the loom off.
have you tried GT4OC, see sig for link.
its a 1992 JDM Celica GT4 ,
I bought the Turbo Timer from eBay and then bought the wiring loom for a celica GT4 ST185 from Graham Good Racing
Jonathan
yeah, but if its a uk loom you may have probs.. post up on GT4OC mate..
cheers for your help, wiring loom fits perfect, just clicks into place and turbo timer works perfect !!
Jonathan
do u know if ur turbo timer has caused ur alarm to change from a thatcham 1 to a 2? some of these t timers play havock with the alarm systems. i.e. greddy, hsk....dont work well with toad alarms, hopefully this hasnt happened to u.
just thought id warn u. insurance companys dont like thatchams turning from a 1 to a 2.
cheers baz :thumbsup:
script taken from toyota owners manual
normal road driving - no idle required
high speed driving 80 kmh - wait 20 seconds
high speed driving 100 kmh - wait 1 minute
hills,slopes at over 100 kmh - wait 2 minutes.
ive got an apexi timer fitted.....works off the ecu....so it know exactly how long to leave ur engine running for. and its really small and discret.
