Electric Window Stopped Working
djtom2000
I have a 2003 Celica and the electric window on the passanger side will not work. The window on the drivers side is fine.
Is there anything I can check myself or will I have to take it to a Toyota dealer?
Cheers
Tom
Is there another button to disable the passenger window operation near the other 2 buttons ? The Yaris has this and is quite easy to press by mistake.
There are 3 switches. On the left is the switch for the passenger window. In the middle is a switch to log the doors and on the right is the drivers window switch.
Do the windows use a fuse to operate?
Cheers
Tom
The switch to disable to passenger window on a celica is located on the dashboard (just to the right of the steering wheel i think)
looks like a window with a cross on it. sounds like this is your problem as COO said.
Mart
  • 8 years later...
