• Join Premium & Save
      Join Premium & Save
    • Huge Range of Toyota Parts
    • Get Your Club Gear!
      Get Your Club Gear!
    • Save Up To 15% Off For Members
    • 1000's Of Toyota Cars For Sale
    • Review Your Toyota
      Review Your Toyota
AdBlock Warning
Parts of this website do not function properly with AdBlock enabled on your device. To get the best user experience on our website, please disable Adblock for this website (domain) on your browser.
Sign in to follow this
Followers 0
Faz_GT4
Tmic Top Mounted Intercooler Coolant
7 posts in this topic
Hi, :help:
Does anyone know what coolant is best for putting into the standard TMIC Top Mounted Intercooler on an imported GT4 ST205?
I've read that the standard intercooler is an air to water cooler, and just needs water. I am not too sure about this tho. I've read that i need toyota red coolant and is the best. I asked toyota about this, they say they are not sure about this car, and they think i should put radiator fluid, but if i want red coolant, they have it in stock.
All i want to do, is clean out my intercooler, which requires removing it, cleaning it out with petrol to removes the dirt/grease, then replace it all, and top up the fluid, but i don't know what to put in there. :ffs:
People talk about upgrading, or moving the intercooler to the front, so they must know. Maybe this is an easy question, and i am the only person in the world who doesn't know the answer, but i thought i'd ask anyway. Any advice would be appreciated.
Thanks to all my fellow GT4 owners out there (and MR2 and Supra dudes who might also be able to help). :thumbsup::thumbsup:
Share this post
Link to post
Hey man, you just need normal engine coolant nothing more nothing less.
Don't put tap water in it or it'll get filled with limescale like your kettle... :D
As for people talking about moving the intercooler to the front, I think you've mis-read a bit there. Their talking about completely removing the standard charge cooler system (Water Cooled intercooler) and replacing it with a front mount Air to Air Intercooler. :thumbsup:
Share this post
Link to post
sketchy has covered it... standard toyota coolant. :)
And come on bro.. show us some pics of your black beast! Looks greta in the avatar... :)
Share this post
Link to post
Oh yea and when you refill it make sure you top it up with the engine running.
Fillup as normal with engine off, then start engine and blip the throttle.
You'll see the fluid level drop as the water pump kicks in. Topup fluid to neck of filler cap then put the cap on.
The way the system is setup the pump only activates when the throttle is pressed, once off throttle the pump stays on for 30 seconds then stops until the throttle opens again.
So you've gotta have either 5 hands to keep blipping the throttle while topping up the level, or blip throttle top up sharpish and get the cap on again before the pump cuts. :thumbsup:
Share this post
Link to post
Cheers Mate. :thumbsup::toast::yahoo:
Share this post
Link to post
or just pull the throttle whilst under the bonnet saves running round and is only 300mm from the CC filler :P
Share this post
Link to post
Off topic but cool avatar Fizz :thumbsup::lol:
Share this post
Link to post
Followers 0
