Reviving My Car?
rockman
This question has always plagued my head, but I was thinking of reviving my 1986 Carina II. That’s if I do get that opportunity.
First, its going to need a new engine. So that could mean the BHP will go over 220+
And I am worried that the car wont cope with that sort of BHP with a front wheel drive car.
Theres a few options:
First: use a 4A-GE20 20valve engine and be enough... thats it.
Second: get the 3s-gte engine. But then comes that question, how well with it cope? will a front dif help or could I fit one in the car?? Or can I get a 4WD drive train? Would that mean chopping up some of the car chassis? Which I hope it doesn’t.
I know apart from power I would need to sort the suspension, brakes and others.
Thanks in advance.
-Rockman
converting to 4WD would be a lot of work, and youd have to do a lot of work to the chassis.
FWD cars have the diff intergrated into the gearbox.
hope this helps
Thanks.
what would be the best solution if I wanted more power over the 220 BHP? As the car looks heavy for a 4 door car plus do you think its possible in a big V8 engine? :D
-Rockman
You could fit a 3S-GTE - they run MKII MR2's through the rear wheels - not just GT4's ;)
You would need to either mount the engine & g.box 180 degrees to how it's nounted in the rear of the MR2 or source another gearbox and driveshafts.
No offense, but why bother going big power on a carina? There will be a load of other stuff you'll need to upgrade like brakes, suspension.
Just better to sell the carina and buy something that's already quicker IMO, although perhaps not as fun developing :thumbsup:
Best get in touch with Dawesy as he's done a 3S-GTE conversion running FWD to his Corolla. He spent a fortune doing it and getting it right.
yeah I checked some of Dawesy post about his 470bhp corolla :eek:
How on earth does it go round bends? and more importantly, how is it keeping all that power with a FWD car?
-Rockman
Anything is possible, but as Garrick has already said its just not worth it. To go V8 you would need to convert the car from FWD to RWD.
i read somewhere more than 250bhp from the front wheels is a bit dangerous? thats for the new mini dunno about carina thoughb
