Installation Сriuse control Yaris XP210.
Yaris210
Hi. There is a Toyota Yaris KSP210 car. I don't have cruise control. I want to install it. A radar is installed on the car, the car sees road signs, road lanes, pulls over if the car drives behind them. But there are no cruise control buttons on the steering wheel, if you install the buttons, will cruise control work?
Engine 1KR-FE 1.0l
  • Sad 1
Cruise is on the steering wheel 🤦‍♂️
13 minutes ago, Parts-King said:
Круз за рулем 🤦‍♂️
I don't have these buttons right now. If I install them, will it work?
  • Sad 1
Sorry I looked at the image and saw the buttons, then you do not have cruise, I don't know the answer, sorry
Engine 1KR-FE 1.0l
On some previous Toyota models, installing cruise control was a matter of installing only the cruise control arm and doing a reset on the ECU. If you live anywhere near a scrap yard or something similar it will be quite easy to find out by your self. Trading car parts with a crashed Yaris can be cheaper than ordering new or used car parts with no guarantee if they'll work.
it's a 1.0 1kr not sure about the P210 but in previous generations, the 1.0 did not support cruise (ecu does not have this function) only a speed limiter
In the UK we only get the 1.5 hybrids so will have to look it up
I assume you are in the land down under, where all wildlife wants to kill you, if so it will be a Japanese-built car for the AUDM
Edit.
you need to check to see if you have radar behind the front Badge
2 types of wheel controls for the KSP210
84250-K0010
84250-K0020
On 09.02.2024 at 23:19, flash22 said:
это 1.0 1кр не уверен насчет P210 но в предыдущих поколениях 1.0 не поддерживал круиз (эбу не имеет этой функции) только ограничитель скорости
В Великобритании мы продаем только гибриды 1.5, поэтому придется поискать их.
Я предполагаю, что вы находитесь на земле внизу, где вся дикая природа хочет вас убить, если это так, то это будет машина японской постройки для AUDM.
Редактировать.
вам нужно проверить, есть ли у вас радар за передним значком
2 типа колесного управления для KSP210
84250-К0010
84250-К0020
Yes, there is a radar installed on my car, on the front under the Badge.
not sure about the programming, but it may be just the case of swapping the controls
  • 4 weeks later...
The question is still relevant.
Find a steering wheel with cruise control and connect it to your plugs.
I have answered your question above, fit the audio controls (with cruise), and try it
the forum is UK based, We only get the 1.5 hybrids here
I have installed the cruise control buttons, at the moment it does not work, maybe you need to register these buttons in an electronic control unit in some program?
How? What? What are we looking at?
Where did you connect that?
How do you drive that considering that cruise control takes over above 30kmh?
Are you trying to un-alive your self?
Why wouldn't you buy the whole turning wheel?
Or since you've done your malakia, why didn't you bother taking out the old ones and install the new ones so car would be safe and drivable?
WTF dude?
On 4/30/2024 at 1:32 PM, jimaros said:
Как? Что? Что мы смотрим?
Где ты это подключил?
Как на нем ездить, учитывая, что круиз-контроль берет на себя управление на скорости выше 30 км/ч?
Вы пытаетесь лишить себя жизни?
Почему бы вам не купить все вращающееся колесо целиком?
Или, раз уж вы сделали малакию, почему бы вам не вынуть старые и установить новые, чтобы машина была безопасной и управляемой?
Что за чувак?
First, read the topic to begin with..
Secondly, you are looking at a photo where there are JUST buttons for a photo on the steering wheel..🤦🏻‍♂️🤦🏻‍♂️🤦🏻‍♂️
Thirdly, they are of course installed in a normal way.
Fourth, I know perfectly well that the cruise runs over 30km/h.
WHY SHOULD I BUY THE WHOLE STEERING WHEEL?
The photo below is especially for you.!!!
Chill...
Greek to English to Russian and back translation tends to mess things up.
And also when you post a single photo I can't guess what you really did. Happy Easter 🐰 🐣
3 hours ago, jimaros said:
Холод...
Перевод с греческого на английский на русский и обратный перевод часто все портит.
А еще, когда ты публикуешь одну фотографию, я не могу угадать, что ты на самом деле сделал. С Пасхой 🐰 🐣
It is written at the beginning of the topic, I do not have cruise control buttons, I purchased them separately. For installation on a car. I took a photo that I got the buttons to install. After installation, I wrote that the cruise control does not work.
It is clear that I did not leave the button as in the photo and that it was impossible to drive like that.
Happy Easter.
