Creaking Clutch Repaired
jimtaxi
:yahoo: yes the creaking has now gone. Anyone with a creaking clutch pedal should get this looked at, the clutch does NOT repeat NOT release properly when the master cylinder is faulty and will cause undue wear to the clutch if not repaired promptly this I think will be my next problem as I have complained about clutch operation since 10000 miles. At the moment the car is OK but I fear not for long!!! Anyone out there had a clutch replaced under warranty?
Yes I have at 38k. They did the clutch and the flywheel , and then took the car back again (as we complained that there was still a odd noise when the pedal was operated) and replaced the some linkage in the pedal mechanism. All under warranty.
