Shift Lights?
corolla02
Hi guys,
Interested in a probably pointless but different mod, a SHIFT LIGHT!
Wondering if they're easy to install to the rolla and can anyone recommend where to get one??
i have a gizzmo tach recall shift light installed there around £100 but really good shift lights super slim.
You will have to connect positive and negative then locate your rpm/tach signal wire. If you can get a wiring diagram for ur 1.6 you will be able to fit it.
Cool so I aint on my own then! Does anyone have any idea where I can get the diagram from and is this signal wire located near the ignition coil?
the new haynes manual should be able to help identify it for you. find one and locate a tacho wire. I tapped mine from the ecu as i couldnt identify the wires behind my clocks they all looked the same to me :| lol. but i had a ecu pin out for a t-sport its differnt to your car.
