Rpm's Please Help
jayt13
I've noitced an issue with the revs when the engines cold.. when i start my car from cold i.e in the mornings etc and i rev the car, lets say to about 3rpm MAX.. when i let go of the accelerator the car de-accelerates and the rpms get stuck at 2rpm for about 1 to 2 seconds, like the throttles getting stuck open.. when the cars up to temp and i do this the rpms will drop as they should?..
Does anyone have any suggestions as to what this could be..
Help much appreciated thanks!
Jayt13
Jayt13
pop your bonnet and check you butterfly is able to flex freely.. if it isnt "free" theres your problem! wd40 should cure the problem in the in the short term
Jayt13
thanks for the quick responce.. but i already checked that n its moving freely not getting stuck at any points
Jayt13
hmm.. thats wierd? and it drives as it should when warm? no engine lights?
Jayt13
the revs only hold at 2rpm when the engines cold but still drives fine n no lights same goes for a hot engine
Jayt13
say to him the revs only hold at 2rpm when the engines cold but still drives fine n no lights same goes for a hot engine
i see! i havent got a clue in that case mate sorry. but i wouldnt worry about it to much.. as if it was major prob the engine light will come on.
its the cold start procedure, like a automatic choke
Hi there, i have a similar sort of problem however it happens all the time engine cold or hot, when i rev the engine as it de-accelerates it holds at that rev for a few seconds and then starts deaccelerating ... any suggestions to a possiable cure for this?
Jayt13
Hi LOZZA_T_SPORT
i still don't understand why it's getting stuck at 2rpm?
