Caburetter Tuning For 2e Corolla & Repair Manual For 2e
schdmitz
hi all, any1 from this forum have the repair manual for corolla EE90 with 2E 12 valve caburetter engine's manual....can u pls share coz i cam across some problem with my corolla ee90...tks
Yes can help ... ... but what area do you reqire info on?
Caburetter tuning and also the firing timing for 2E & valve clearence....tq v much
2E engine tuning data ( for Singapore Market ) :
Spark Plugs
NGK BPR6EY or Nippon Denso W20EXR-U
Spark Plug gap 0.8mm
Ignition Timing
10 degrees BTDC (with sub-vac pipe off)
Valve Clearance - check when hot
Inlet 0.20mm
Exhaust 0.20mm
Idle Speed
manual Transmission 800 rpm
auto trans 850 rpm
CO %
1.5 ~ 2.0 %
Engine Vaccum
18.62 mmHg or more ( engine hot and at idle )
Hope this helps,
Mick :thumbsup:
Spark Plugs
Ignition Timing
Inlet 0.20mm
Exhaust 0.20mm
Idle Speed
auto trans 850 rpm
CO %
1.5 ~ 2.0 %
Engine Vaccum
Hope this helps,
Mick :thumbsup:
tks....may i know where is the location for sub vac pipe?? :P :D
On the distributor ;)
ok thank you....is there ant where to modified the air intake on the 2E engine....esp the air suction to boost up the power of the engine...
