Brake Pads + Discs 1.4 T3
shabz_81
Pads and discs need changing all round was looking at Mintex or standard oem. I understand the discs come in different sizes. Was wondering if anyone knew which size would fit the 1.4 T3.
Front 255mm
Rear 258mm
This is on UK built cars, Mintex link Mintex click on catalogue and drill down to Toyota then into brakes etc, watch out you don't pick the Japan Part numbers if your car is a UK one.
You can take the MDC numbers to your local motor factor and they will order them in, much better than OEM IMO.
