Kia Wheels On Auris
kingdragon
Hi there.
I would like to ask you if kia alloy wheels can be put in an Auris.
Regards.
Hi there.
I would like to ask you if kia wheels can be put in an Auris.
Regards.
If they are in the same size then yes- for Auris 1.6 6.5J/ET45- 205/55
yes, they can, you need a set of 8or10mm spacers and a set of 67/60mm centerings.
Basically to explain exactly what I mean...
I have found 4 alloy wheels 7x17 from a Kia with 5 stud and tires with a size of 225-45/17 with just 1700 miles driven.
'welcome!
after you put the rims on, pls. take some pcs. and show them us.
Ok I promise! Next Friday i will put them. :thumbsup:
"I have found" :thumbsup: nice one!!!
It's an expression we use in Greece when we bump into something very cheap.... :drool:
As promised 225-45/17 Continental SportContact 3 with Kia Cee'd 7x17'' alloy wheels...
Sorry for the pics quality my mobile is only 2 mp I will post new ones taken from my digital camera. :thumbsup:
Looking nice! Now the only thing it needs is some lowering ;)
Best regards, Alex
I will do coonsider some lowering later on but because this car being the one that I use to do about 100 kms everyday to work and also using it as family car here in Greece with the worst roads probably in Europe I'd say 4cm would do the job!
Thanks alexC and tavy
