Aygo Blue Bluetooth Not Working
Jimmy Grimble
Has anyone else experanced problems with this system or is it just my car i brought the blue as it had the bluetooth which is vital as i am a ambulance responder in my spare time and i need to be able to answer calls on my way to jobs but the system disconnects randomly and doesn't want to hang up oh and the sticky pad that holds the unit in place isn't stick anymore the car is only 3 months old! going back to the dealership tomoz will post what happens then
yes i have tried other phones
On rare occassions I have had to stop and turn the engine off to power down the bluetooth as the person 'at the other end' cannot hear me, but I can hear them.
It has only happened about3 or 4 times since I bought the car a couple of years ago.
BT in our Blue has been faultless. Voice commands a bit dubious if there is too much noise ;) but otherwise its been reliable and never had any issues.
As yours is under Warranty I'm sure they'll simply repalce/swap out the unit.
I have to agree mine has been faultless, I have it set up for three mobiles.
The only issue I have is a problem when I have the fan on, I'm told my voice is softer so when the phone rings I knock off the fan for a bit. thumbsup.gif
Where did they place the mic on your car? Next to the interior light?
Might be noisereduction kicking in becuase of the air movement.
Try if putting the air on your feet helps, if so, find a new location for the mic...
Hi all just got back from the dealership they have checked all the wires and re stuck the control unit onto the windscreen but coundn't find a problem a little test by me on the way back home no problems lets hope it stays that way!
