Squeaking Suspension
toyota_query
I have a 2007 2.7 VVTi Hilux double cab bakkie and the squeaking/creaking suspension is driving me crazy. Most of my friends in the area are struggling with the exact same problem. When we speak to any of our Toyota dealers they just say "it is a hilux problem. I don't accept that answer. Can anyone advise on what I can do.
bakkie -> sa?
any way, the rubber bushes might be dry? or the leave springs covert by dust?
you can see if you can change those rubber bushes with poly bushes
  • 1 year later...
bakkie -> sa?
When i had this problem it turned out to be the steering bumpstops rubbing on full lock. A bit of copper grease soon sorted it out.
Hope this helps,
David
