T Sport Help Urget
alasdair09
Basically facelift t sport. Lost clutch pedal couldnt get into gears looked underneath found brake fluid leaking looked on top of the gearbox and found brake fluid ontop of the box it looks like theres a brake pipe that runs ontop of the gear box is that common to go or anything else. Thanks
possibly burst flexi pipe or most likely your clutch slave cylinder is peeing out fluid.
its coming from the back of the box not the front so im guesing its the pipe that goes into a flexi one i guess as its rubber casing, is it an easy fix to do or cost much to do, ive got a 3 months warrenty cover but it says parts only for the clutch but its external to the gear box (with the clutch its parts only not labour)
