My Ac Is Not Working
joe4
I recently got my ac fix in my coralla by professionals. but then i realised that it is not working now, it has in refrigrant. however, i was wondering if the problem could be a blown fuse in the fuse box. I can someone help me. thanks very much.
when you press the AC button, does the RPM of the engine increase? if it doesn't you've probably blown the fuse.
Either that or you are gassed out again. Happens if you topped up the car with R134a gas without fixing the leak on the pipework.
Press the a/c button and hear for the click of the air con compressor clutch engaging.
If not check the fuse for it.
