Sluggish Surf
clack
Hi chaps
I have just bought a early 2.4 td surf. It seems very sluggish. I took it for a run and it struggled to hit 70 and just doesnt seem to have much grunt. The turbo whistles but it just doesnt seem to want to go above 3000rpm.
Any ideas?
Hi chaps
Any ideas?
Sorry to say that even new the 2.4td was no ball of fire but has it been serviced recently clack ?
I was going to suggest having a word with the lads on the Surf forum but it looks as though they`ve had a bit trouble. :unsure:
http://www.hiluxsurf.co.uk/
Yeah I checked that site earlier. Been doing a bit bit of reading up and seems they are prone for cracking the head So im getting the willies about it now!!!
Hello Clack,
I Have A 3 Ltr Surf Which Is not SLOW but to Check A few THINGS out on you 2.4Ltr. you should try the following things in this order of cost!
Make sure the breaks are not binding.
Change the fuel filter
Do a Compression test.
I think you would know the head was going by overheating problems.
A whisteling turbo is not a good sign however so that could be your problem.
