Pressure Building Up In Water System
andy364
hi i have a 1992 k plate 2.2 td lucida yesterday on the way to work i lost a lot of water from the bottom pipe by the rad so i waited for it to cool down and filled it with water and since then it has not lost any water since but i,m still getting the pressure build up any ideas.
When you say it lost water from the bottom pipe do you mean radiator hose or overflow pipe ?
Hopefully it might`ve just been a sticking themostat or an air lock in the heater system, but it may also be a head gasket :o
