marsbar989 0 Posted June 28, 2010 Share Posted June 28, 2010 Car is a 1.8 Avensis 1999 V reg. 96,000 miles on clock. I have owned it from 65,000 miles as 3rd owner. Covered 30,000miles in last 2 years. Problem I have is that in gears 2/3/4, if you accelarate anything more than gently, then the engine revs go up but the engine speed doesnt. It is as if your foot in resting slightly on the clutch. Which it isnt. Does this from cold or hot engine restart. However doesnt do this all the time. But more often that not. The car is due an annual service and I will mention it then, but any clues? Quote Link to post Share on other sites
Nigebob Squarepants 10 Posted June 28, 2010 Share Posted June 28, 2010 Car is a 1.8 Avensis 1999 V reg. 96,000 miles on clock. I have owned it from 65,000 miles as 3rd owner. Covered 30,000miles in last 2 years. Problem I have is that in gears 2/3/4, if you accelarate anything more than gently, then the engine revs go up but the engine speed doesnt. It is as if your foot in resting slightly on the clutch. Which it isnt. Does this from cold or hot engine restart. However doesnt do this all the time. But more often that not. The car is due an annual service and I will mention it then, but any clues? Quote Link to post Share on other sites
Nigebob Squarepants 10 Posted June 28, 2010 Share Posted June 28, 2010 Car is a 1.8 Avensis 1999 V reg. 96,000 miles on clock. I have owned it from 65,000 miles as 3rd owner. Covered 30,000miles in last 2 years. Problem I have is that in gears 2/3/4, if you accelarate anything more than gently, then the engine revs go up but the engine speed doesnt. It is as if your foot in resting slightly on the clutch. Which it isnt. Does this from cold or hot engine restart. However doesnt do this all the time. But more often that not. The car is due an annual service and I will mention it then, but any clues?Sounds like a NEW CLUTCH TO ME! Quote Link to post Share on other sites
Big Kev 513 Posted June 28, 2010 Share Posted June 28, 2010 Aye, Laddie.....methinks the title of your posting is as good a hint as yer gonnae get...yer clutch is making for the exit sign.....it's on its way out.Big Kev Quote Link to post Share on other sites
Cretin 0 Posted June 29, 2010 Share Posted June 29, 2010 Aye, Laddie.....methinks the title of your posting is as good a hint as yer gonnae get...yer clutch is making for the exit sign.....it's on its way out.Big Kev How hard is it to replace the clutch? I'm thinking of doing mine but wondered how difficult it was and if you'd need any special tools..Will Quote Link to post Share on other sites
