Is Bigger Always Better?
cynosbob
what are the biggest injectors 4 a toyota and would it be anygood 2 put them in2 a 1.3 with work done to it??skimmed head port and polished cold air feed better gearbox and clutch better camshaft and remaped..bout 150 bhp
first of all, bigger isn't better. you cant burn more fuel unless you can get more air in there. a port or polished head might help very slightly but not enough to use bigger injectors. you will not get 150 bhp from the 4efe. its possible if you spend 10 grand maybe. your best bet for power gains is to fit the 4efte from the turbo starlet.
[quote name='*rollaboy' date='08 August 2010 - 12:46 AM' timestamp='1281224802' your best bet for power gains is to fit the 4efte from the turbo starlet.
Agreed - it's a straight forward job - even the engine mounts are the same as you have now. 135 as standard IIRC. Certainly the best BHP/£ gain you can get
