Sign in to follow this
enyajtrebor
Corolla 1.8 Vvtl-I T Sport
Looking at purchasing a post 2004 plate 1.8 VVti Sport.
Do they suffer from Oil burning problems like the normal 1.8 VVti and anything we need to look out for
Thanks for any help
Share this post
Link to post
Do they suffer from oil burning problems like the normal 1.8 VVti and anything we need to look out for
Thanks for any help
I've never needed to top up my 02 T-sport with Oil between services and theres now 120k miles on the clock.
When you're testing it, just make sure you let it warm up to normal, then give her some welly and you should feel a real surge of power ("lift") when it reachs 6.3k revs! Other than that just do the normal checks when you're buying any second hand car...
Edit:- make sure the heater works and gets fully hot... Some have had problems with inside rads...
Share this post
Link to post
Thanks for any help
Share this post
Link to post
be sure the vent next to the drivers windows kicks out hot air.make sure the seats move properly .
Share this post
Link to post
i change the Oil every 10,000 miles, it takes about 4.2l, so i buy 5l, then top it up after about 7000 miles with the bit of Oil thats left over.
Wouldnt say it uses lots of Oil, just best to keep it full.
and as other people have said, make sure you hit lift just after 6000rpm, and i think the slider pins were a problem on some of the older tsports
Share this post
Link to post
i change the oil every 10,000 miles, it takes about 4.2l, so i buy 5l, then top it up after about 7000 miles with the bit of oil thats left over.
Wouldnt say it uses lots of oil, just best to keep it full.
Seat slider pins?
Share this post
Link to post
is there anyway to fix the seat slider? my 1.6 pfl passeger seat does not slide anymore :(
Share this post
Link to post
You will need to order in new pins from Mr. T, they have snapped if it won't slide anymore, a common weakness. :(
Share this post
Link to post
Thanks for any help
sent a PM!
Share this post
Link to post
