Sign in to follow this
VVTi man
Obd Or Obd2?
Hi, I'm new to this forum.
Can anyone tell me please what protocol my year 2000 Corolla 1.4 VVTi is?
I've tried scanning with a OBD2 scanner that supports OBD2, EODB, CAN BUS but doesn't seem to work. Display says 'linking error'.
Anyone help please
Steve
Share this post
Link to post
Your post moved to Corolla Club...........Where (hopefully) you should get a reply from a corolla owner!
Share this post
Link to post
99% is OBD2. The obd1 is for older cars.
I have a 2004 corolla (but I think that we have the same engine on (4zzfe) and I use an OBD2 scanner without any problem.
Share this post
Link to post
Most obd2 scanners will only read vehicles from 2001 onwards.
But i am not sure about obd.
Share this post
Link to post
OBD2 was only mandatory in europe from 2001 onwards, so if its earlier than that it might have OBD or OBD2! OBD generally resulted in awful implementation from manufacturers due to shoddy standardisation, and its mostly useless especially with a generic device.
You should be able to tell what protocol it uses by the the used pins in the OBD connector.
1. Manufacturer discretion. GM: J2411 GMLAN/SWC/Single-Wire CAN.
2. Bus positive Line of SAE-J1850 PWM and SAE-1850 VPW
3. Ford DCL(+) Argentina, Brazil (pre OBD-II) 1997-2000, Usa, Europe, etc.
4. Chassis ground
5. Signal ground
6. CAN high (ISO 15765-4 and SAE-J2284)
7. K line of ISO 9141-2 and ISO 14230-4
8. -
9. -
10. Bus negative Line of SAE-J1850 PWM only (not SAE-1850 VPW)
11. Ford DCL(-) Argentina, Brazil (pre OBD-II) 1997-2000, Usa, Europe, etc.
12. -
13. -
14. CAN low (ISO 15765-4 and SAE-J2284)
15. L line of ISO 9141-2 and ISO 14230-4
16. Battery voltage
Share this post
Link to post
Haynes manual says that all of the VVTi Corollas were OBD2, as has been said, ready for the 2001 requirement, so your car should be EOBD/OBD2 compatible. Does the scanner work on other cars?
Hope that helps :thumbsup:
Share this post
Link to post
