Tweeters In T-Sport - Help!
chani
Hi all,
Just a quick question, since I've changed my headunit in my Corolla T-Sport to an aftermarket Clarion headunit, the tweeters in the car do not work, Im sure alot of you may have had the same problem, is there a solution to getting them to work again with an aftermarket headunit? Id appreciate any advice, Thanks.
Have you checked the wiring at the source, meaning at the tweeter, then try and check the rest of the cabling leading from it.
From what memory serves me right, the wiring to the tweeter and mid-range speaker splits off somewhere in the door.
Saying that, does the mid-range speaker at the botom of the door work ok too?
I can't really say i have a problem like what you got, as i had it all rewired leading to the amp in the boot, so it's all seperated.
