Starlet Clutch
cheekybum
First post,be kind to me!
1985 Starlet with a slipping clutch,can some-one give me a walk through to swap in a replacement,please?
Busy forum!
Sadly there aren't many on here with a starlet that old.
Generally it is drain gearbox oil, remove passenger hub, remove drive shaft, remove gearbox, do clutch, reverse.
Sorry I couldn't have been more helpful
Thanks,looking at the little bugger,I was expecting to have to remove the entire drive train!
Is the L/H hub straight forward?
Would guess, without looking at it, that it is wheel off, unbolt the two bolts at the bottom of the strut, remove the nut that secures the driveshaft, remove the wheel bearing and pull the disc towards you
Thanks for your help,I bought the thing cheaply 12 months back but 'er indoors has become attached to it,as they do...I've found a 'clutch kit' on the 'tinernet for £70 so was thinking of getting it in the garage and having a go!
I'm a BMW man at heart,so I am used to RWD...
It's not old at 26,I'm more than twice that!
Oldest starlet I had was a 1990 so first of the ep82 shape where yours is ssomething like a ep71
You might be able to get a haynes manual online for it, have a cheeky google
Sorry,not used to this forum's workings yet,not even Mr Haynes knows about this sorry !Removed!,no,that's not quite right,this last week it's turned in 45mpg,when 'er indoors uses my BMW for work I'm lucky to see 18mpg...so if I can fix it up cheaply it's worth the effort!
I'll have another look at it,now I have your advice to work with.
Many thanks.
You will not get replies as you have posted this in the General news articles.
Try posting it in the Starlet section of the club mate
