1998 Landcruiser Overheating
SGP
I have had my Landcruiser Colorado for 5 years now and i have had this problem for about 2 years now.
The problem is that when ever the car goes over 70 it will over heat and the water in the radiator will dry up.
If i dont check the water after 3 or 4 days it gets empty.
I dont know whats wrong with it i have taken out the thermostart and changed the radiator cap.
Could someone please help me out this problem is just getting worser and worser!!!
hi mate
is cooling system provided with an expansion plastic tank? the most prbably this tank cap seal ring got worn down. check with it firstly. by the way - you did not mention any coolant traces under the engine. are they available after a night?
what is going on in static condition when the cooling system is full of coolant???
Cheers/Igor
