Sign in to follow this
adrock11
Cold Air Feed On A Pr Facelift Cts
how can i get a good air feed on a pr2002 corolla t sport it looks like im going to go straight down to the under tray , pics and ideas would be apprecited :thumbsup:
Share this post
Link to post
There is no way to fit a straight CAF, you can remove the n/s fog light and run it from there up through the hole the air pump sticks through, if you have removed the standard air snorkel, you may nee to move the air pump a bit to get it through.
I have not done it but that is the straightest way of getting the CAF done from what i can see.
Share this post
Link to post
if you remove the Battery, youll see a gap behind the n/s/f headlight. you can run a pipe straight down there, next to the air pump and across behind the lower grill on the pfl. ill get some pic of mine soon.
Share this post
Link to post
Nice one didnt get looking that far. Now i wanna see this pic :thumbsup:
[/quote with the battery out is just enough room to get down but it's tight , i think im going to have to remove the under tray to get it properly fitted a pic of how you got it infront of the rad would be greatly apprecited mate :yes:
Share this post
Link to post
Ive got pics of the top of the engine bay. But to show the routing properly id have to take the bumper off. Altho i didnt remove the bumper to fit it. Battery and undertray have to be removed to fit. Ill link you to thw kit i used also.
Share this post
Link to post
Might sound like a bit of a twonk but what is this for?
Share this post
Link to post
Cold air feed. Does exactly what is says on the tin. Feeds cold air.
Gathered that not totaly stupid. :ffs:
But cold air to what?
Share this post
Link to post
Air filter mate. The colder the air the denser it is. The denser it is the more oxygen it carries. The more oxygen air carries the bigger the bang will be. X
Share this post
Link to post
O.K. Thanks for explaining :thumbsup:
So this is no good for a standard air filter then only K&N's etc? :unsure:
Share this post
Link to post
Chay installed one for his standard airbox and just upgraded the panel filter thumbsup.gif
Share this post
Link to post
Nice :thumbsup: Might give it a go when it warms up a bit :lol:
What is the pipe being used type, make etc?
Thanks.
Share this post
Link to post
i didnt think it would fit behind the headlight , thanks for the pics but no i need to find out why the trc,egine ligts have come up? one problem sorted then one starts :ffs:
Share this post
Link to post
