Vsc On, Trc Off Light On
Pinza
57 2.2l D4D, 50k service 2 months ago, now the vsc,trc and engine mngmt light on. Last week they appearred for one day and went out for a week, now their back and on for 3 days. Any ideas?
All lights off now. How much and where would i find a cheap tuning box? There doesn't seem to be anything wrong with the car so I'm baffled as to what's triggering the lights
I think he was suggesting that if you had a cheap tuning box fitted then it may be causing these problems.
You need to get an ODB2 code reader plugged in which will read an error code that will tell you where to start looking for the problem.
I believe the most common cause of these lights on an Avensis is a faulty EGR valve. I also have a 57 plate Avensis (although much higher mileage) and had the same lights. Cleaning the EGR valve did not help, replacing it did.
