Angel Eyes
Number1Norton
I'm not sure there is such a thing for the Aygo headlights... I know that some 107 owners have got hold of some but the fit doesn't look the same for our headlights?!
Headlights between the three are WAY different. So you can't swap them out.
And there are NO aftermarket lights for the Aygo what so ever...
some chromed indicator bulbs to get rid of the 'fried egg' look!
We call 'em "Sleepy eyes", but I agree, was one of the first things I did:
Before:
After:
Lit:
I've uses "Chromium" bulbs by Carpoint, but I'm not sure you can get those in the UK too.
Philips has them, as well as Osram and Sylvana, but the latter are kind of expensive.
My Chomiums were less than £3 for a pair of two.
Make sure you get the ones with the pins at 120º instead of opposite at 180º, else they won't fit!
Think i will be buying them tonight :P Are they hard to fit. In my MINI i had Nightbreaker bulbs, do they do then in H4 form? Are the sidelights W5W's?
Sorry for all the questions.
No, they're not hard to fit, here's a picture from the manual:
And a picture of the bulb and its sizing:
I THINK NightBreakers ara available as H4 too, no experience with them.
And yes, sidelights are W5W / T10.
Just about to order them. Do the rear indicators take the same ones? Has anyone put LED's in the side indicator bulbs and are they easy to fit? The W5W's, can you put LED's in them?
Rears do NOT take the sae, they're just plain white bulbs like the reversinglight and the rear fog light.
Putting Chromiums in them would be useless too, as the lights get their color from either the lens
or the colored inserts. You CAN remove these inserts on the pre-facelifted cars, but then you
lose some of the spreading these inserts seem to give.
I've fitted ED to my rear brake / stop lights. they are about 15% brighter and light up faster as well.
