Alpine Head Unit
y4ris
got my double din very nice but dose anyone know what the labels on the wires are the manual is jap and its not a uni block on the back
the labels are:
In Int
Remo
P.Ant
acc
ILLM
hi....got my unit today and wired up to a Battery to test...LOOKS AMAZING......
what wires you struggling with?,i pute
BATT=PERMANENT LIVE
BLACK=EARTH
ILUM=LIVE(not sure if should be ign switched)
think ACC should be an ignition switched wire too....dont know what wires are in the car but will be fitting tomorrow and can tell ou then if not found out by then.....
put it all in still dont know what P.Ant is so i did not hook it up all works fine.
mine was all labeled on the old uni block converter it said it on wires so i just matched up and conected pic comin soon.
If some one tells me how to get them up
cheers
OBIE OUT
P.Ant is power antenna sense - basically its a remote lead that tells the antenna to extend, think it can also be used as an amp remote if its a 12v signal
mine fitted now too,took a while using a probe to
work out car wiring,i used pwr ant wire due to electric
aerial,dam looks good and so many buttons to play with,still trying to
work all them out.
