Wing Mirror
cathy999
Hello
Can anyone give any advice on fitting a new right hand full wing mirror.
Woke up this morning to find someone had totally smashed my mirror ,it was left dangling.The mirror is ok its the black casing that holds it to the door that is totally smased they must of drove at some force or speed.Just bought one from bms for 40 pounds I was really gutted this morning the car is only a few months old its a toyota aygo.Any help would be great on fitting it.
Cathy
Pop off the cover at the inside of the door that closes upto the dashboard.
Remove the screws that become visible.
Pop off the inner trim.
Undo the bolts you can see sitting inside the A-pillar on the door and the one
you can allways see above the door hinge on the leading edge of the door.
Now ease the lower side of the mirrorcasing away from the car for
about 1" and then lift it upwards to undo the hook that supports it.
Refitting the new mirror is the opposite of above.
Good luck!
