How To Remove Back Seat?
rajivrattna
I want to sound insulate the rear part of my Aygo (below the spare tyre and the rear seat). How does one remove the back seat? Where are the nuts and bolts and how many of them? Is there a diy some where? Thanks in advance.
if you lift the seat base up youll see the 12mm bolts you need too remove iirc theirs six two on each side and two in the middle...
