Mot Brake Test
tatteam
Now that MOT is approaching, I have a concern regarding Brake Test on rollers.
Seen the pinned chapter regarding the issue but,
Is it safe to brake test on rollers using wheel being tested turning forward, whilst the opposite wheel will be turned backwards, thus avoiding the diff and prop shaft to turn.....
Does the wheel speed sensors still try to control the VSC ??
Most garages will use a Tapley Meter if there are any concerns with the transmission. You can always disable the VSC but I'm not sure if reversing the rollers will help. These systems are very clever these days.
Thanks mate, better not to take any chances then and desable the VSC.
Up here, a Tapley Meter is a gauge for recording how many times a mate asks you for a loan of £20.00. My first MOT is 27/3, and is being done it my local Mr.T, SO ONE PRESUMES HE KNOWS / HAS A TAPLEY DOODAH FING....?
Big Kev
Big Kev
Big Kev
If he breaks it he can fix it. They will lend you a Ford Ka while they do it.
PS When are you going to pay ME the £20 I lent you???
I'm pretty sure dealerships don't do the actual MOT, they out source it to their local backstreet mot garage :D
Check the address on the MOT certificate :thumbsup:
Big Kev
Big Kev
....when ah get ma dashboard bits back.....
Big Kev
Big Kev
Damn. I have nearly built another SR180 out of the bits I've won off your 2 cars. I suppose you want the steering wheel back too?................................
Big Kev
Big Kev
....and ma prototype 2AF engine block....
I'm not sure if its normal, but when I've tried to disable the VSC by shorting pin 4 and 12 on the DLC3, several alarms came out including P/S , ABS and VSC were flashing.
Is it normal or better to stay OFF DLC3 shorting out ???
If you are unsure, the brake and handbrake method works quite nicely.
Yes tried that option too, works fine, only VSC flashes.
Thx.
It's normal.
