Drivability
fixemup
Hi!
I'm new here. My 95 Carina shudders in drive with brakes applied. My guess is either engine mounting or improper tune up. Any suggestions would be greatly appreciated.
Thanx all!
Hello Could be a warped Disc/discs. Is it happening all the time? Ive seen a worn bottom balljoint causing shuddering when you brake.
Could also simply be that your dics pads are on the metal and need replacing!
