Cts Induction Kit Help.
iAdamWhy
I'm currently fitting an induction kit by K&N and was wondering where the vacuum pipes go and the oil breather?
I have heard you need to blank off certain pipes? And one need to by put on the induction kit?
Any help would be great!
I put a screw in each one ,make sure youve disconnected the Battery for atleast 30mins before hand.then take it round the block give it death and you wont have an issue
Just installed the K&N typhoon kit, the sensor has been plugged back in and the two vacuum pipe blanked.
My engine management light is on, aswell as the TC light and another.
Will disconnecting the Battery as you said fix this??
All sorted now! Thanks
