Glove Box Door
andyy94
Hi, I was just wondering where I can purchase the 'newer' glove box lid (the one with the handle that slides down and is meant to be better) for the Aygo? I found some on eBay but they only show a pic with the glove box open so I'm not sure if this is the correct one? Any links or part number would be appreciated. This one I think it is:
Thanks in advance :)!BU9uYqQBWk~$(KGrHgoOKiEEjlLmf)k0BKQK(j5roQ~~_1.JPG
I got mine from eBay and the seller was a Toyota dealer, Just message them asking if this is the later version.
BTW i paid £25.80 from seller wrmgbradford. if you look now there is some listed by this seller.
£25.80 is a good price (but still expensive for a bit of plastic!).
I have never understood why the door does not just come with the car. The manufacture cost must be in the pennies rather than the pounds.
I got mine from Toyota £26 i got the same one as you with the slide lock rather than handle its perfect :) fits nice and easy you just need a small screw driver you will need to make sure it says RHD when you purchase it since your in England and your Aygo is Right Hand Drive
