Avensis D4D 2.0 Starting?
avensisd4d786
hello guys, below are 2 videos of my avensis 2.0 d4d 2004 t spirit starting, is this a normal start for the avensis to me there is a delay before it starts, If there is anything please point it out as I do not want trouble through the upcoming winter. any advice guys.
What delay?
If anything the Battery sounds a little sluggish, on some older models the starter motor was the problem and not the Battery, where the starter would not spin the car over quick enough, but to be honest, yours sounds quite a reasonably quick turnover
You should make sure all the normal diesel checks are done before winter, check for water in the diesel filter (or just change the filter) you could also check the resistance of the glow plugs, apart from that, just enjoy your car and dont worry too much :D:
Kingo :thumbsup:
What delay?
If anything the battery sounds a little sluggish, on some older models the starter motor was the problem and not the battery, where the starter would not spin the car over quick enough, but to be honest, yours sounds quite a reasonably quick turnover
Kingo :thumbsup:
Cheers, Thank you kingo, Filters have been done, shall get Battery tested over the weekend.
check with:
- output from an alternator;
- Battery
The current status og the Battery is about to die.
The engine idle is OK - nothing to be worry about
regards / Igor
check with:
- battery
The current status og the battery is about to die.
regards / Igor
Thank you Igor.
