Will Buy Avensis
JAPCAR
I intend to buy diesel Avensis 2004-2006, so I would like to ask some initial questions:
1. Is the face lift November 2005 ?
2.Which of the engines are with cam chain (not belt)?
-2.0 116hp (before facelift)
-2.0 126hp (after facelift)
-2.2 ???hp
3.What does it mean T2, T3....?
4.What depends mainly insurance category of- engine power or liters?
How to check which category is Avensis according to engines?
answers to some of your questions.
The new facelifted Toyota Avensis became available in June 2006. Some changes from the old model are the inclusion of turn signals in the side mirrors, an MP3/WMA/ASL-ready audio system, new front bumper, and a new grille. Interior materials and cloth seats have also been changed for 2006. Its multi display with on-board computer will be integrated in optitron display and is navigation ready. Also added are automatic headlights and a height-adjustable front passenger seat.
The most notable mechanical difference is the addition of a 124 bhp (92 kW) D-4D engine. This, coupled to a six-speed manual gearbox, has lowered fuel consumption, emissions, and gives a quoted 0-60 mph time of 10.5 seconds.
[edit]Engines
  • 2.0-litre D-4D 1AD-FTV 93 kW (125 hp)
  • 2.2-litre D-4D 2AD-FTV 110 kW (148 hp)
  • 2.2-litre D-4D 2AD-FHV 132 kW (177 hp)
In regards to t2,t3, these are trim/grade levels if you go onto toyota.co.uk click on used cars,along the top click on used cars, drop down menu should appear, click on the one preferred example 2004, then click on avensis hatchback/saloon.
example for the 2004:
please click on the link - http://www.toyota.co.uk/vs2/oldpdf/04/AV3_63_over.pdf
also it will give you different engines available in that year.
also check this post out http://www.toyotaownersclub.com/forums/index.php?showtopic=139173&hl=avensisd4d786#entry1230419
Thanks for the answer.
I realized it's to complicated for me to choose the engine according to my requirements...
I saw there is engine Power 116 ps (85 kW), probably before facelift...I interested of facelift just for gadgets, but is not important.
I prefer engine with no big power, cam chain, no turbo but probably it doesn't exist such set...
I even don't know does it exist Avensis without turbo...
I bought Avensis 2006, facelift, D-4D, 2.0, probably 126hp. Would you provide me any VIN checker...I even don't know if the engine is with chain or cam belt?
I will be thankful if somebody give me a link to any manual for 2003-2008 Avensios because there still no Haynes manual and the Autodata is no useful...
most probably chain. the older 115bhp d4d 2.0 are belt driven, if its an alloy engine it will be chain, if its cast iron it will be belt.
which trim level did you get I know you wanted one the gadgets.
I personally think the 1cdftv is the pre facelift 2.0 d4d engine.
and was replaced by the 1adftv.
some info i found.
the Toyota CD engine is a 1,995 cc (122 cu in) diesel engine used in the Toyota Corolla, RAV4 and other vehicles. It is a DOHC engine with a bore of 82.2 mm (3.24 in) and stroke of 94.0 mm (3.70 in) with 110 hp (82 kW). The CD Series engines have now largely been replaced by the AD engine. There were two versions: the 1CD-FTV and the more powerful 2CD variant.
AD-FTV
1AD-FTV Manufacturer Toyota Production 2005-present Displacement 1998 cc Cylinder bore 86mm Piston stroke 86mm Compression ratio 15.8:1 Fuel type diesel Power output 126 bhp (94 kW) Torque output 310 N·m (229 lb·ft) at 1600 - 2200 rpm
  • Turbocharged
Applications:
My Car is T3-x, there is small trip computer info display in instrument panel, but no big display and navigation...
Yes, 1CD engine is 110hp, and 1AD is 126hp.Probably everything is the same, but bore and stroke.
Because this is my first diesel car I would like to ask if engine oils for diesel and turbo diesel cars are different (general question). I know I need to have a look in User manual for particular oil and interval of change it...
This is what the t3-x consists off
T2
The Avensis range starts with the T
grade with
features that include:
8 speaker audio system with steering wheel
controls
Front grille, body colour with chrome surround
Full colour coded exterior paint
ABS with electronic brake force distribution
Optitron instrumentation
9 airbags (including driver knee airbag)
Adjustable steering column, stepless reach amp;
rake
Multi adjustable front seats, manual
Double locking, remote alarm and engine
immobiliser
Manual air conditioning
Front electric windows
16" steel wheels with full wheelcaps
t3-x
Additional comfort and luxury are applied to the T
to shape the T
3-X
with extra features such as;
Instrument panel and centre console with
metallic effect
Fog lamps, front and rear with automatic
cancelling
Leather steering wheel and gear knob with
leather and metallic effect
Dual zone climate control air conditioning
Rain sensing wipers
Front and rear electric windows
Door inserts with carbon fibre effect
try http://www.eurocarparts.com type in your reg & it will tell you what oil is suitable for your car. Mine uses 5w 30 & every 10,000.if you still unsure refer to your user manual.
What is this?
Thank you for useful link. It gave me the same- 5W30 synthetic or semi synthetic.Probably synthetic is better.
I thought for this engine, on the oil label should see "For Turbo Diesel"...because I think 5W30 use many petrol engines as well...
