sarathrp88 0 Posted November 25, 2012 Share Posted November 25, 2012 HELLO ALL,I NEED TO HELP ON THIS MATTER I AM HAVING PROBLEMS WITH MY COROLLA LE 2006 IT HAS WHEN THE A/C IS OFF AND CAR IS ON ITS TEMPERATURE NORMALLY THE IDLES ARE VERY LOW 615 AND EVEN 600 AND START VIBRATING. WHEN I TURN THE A/C ON THEY GO UP A LITTLE BIT.WHEN CAR IS COLD ITS PERFECT UNTIL ITS ON ITS NORMAL TEMPERATURE THIS CAR IS REALLY DRIVING ME CRAZY. I HAVE CLEANED THE THROTTLE BODY EVEN TOOK IT OUT AND CLEANED IT COMPLETELY AND STILL SAME ISSUE, THE ONLY THING I HAVE NOT DONE IS CHANGE THE INTAKE MANIFOLD GASKET SINCE I SAW A RECALL BECAUSE IT HAS NOT GIVEN ME THE P0171 CODE.I SCANNED THE VEHICULE AND IT HAS STATED IN THE RECALL IS THE SHORT FT IS - THAT I NEEDED TO CHANGE THE INTAKE MANIFOLD GASKET BUT LIKE I SAID BEFORE I DONE HAVE THE P0171 CODE.I USE TECHSTREAM TO SCAN THE VEHICULE PLEASE SE BELOW ALL THE INFO I GOT AND PLEASE HELP I AM EVEN THINKING OF SELLING THIS CAR I AM SO DISSAPOINTED IN TOYOTA FOR ALL THIS ISSUES.I ALSO FEEL THE CAR HEAVY LIKE SLOPPY AFTER ITS NOT COLD.http://postimage.org/image/qi5bt6367/http://postimage.org/gallery/6hvc4p0c/9bdcb660/ Quote Link to post Share on other sites
T25-AVENSIS-D4D 0 Posted December 2, 2012 Share Posted December 2, 2012 Hello sarathrp88!Your car has recall for inlet manifold gasket? Quote Link to post Share on other sites
